To create a BOM in a detailed drawing you use a parametric table called a repeat region. From what I have read, using MBD the BOM should be attached to the assembly in some way as an annotation maybe. Anyone have any comments on this ??? Maybe I'm missing something or we are not there yet in creo 9 thoughts? Maybe I need to join the MBD technical committee 😉
Bart Brejcha
