MBD: To Hide or Modify the labels related to Combined states
Karthik_1
8-Gravel
I am trying to hide the labels related to active combined states like Layer state , apperanace state etc.
Also i want to modify or hide some times, the tolerance table label appears in the bottom right corner of the combined state.
But i am not able to find any options to hide or modify these labels. Is it a limitation ? or is there any settings to control it. Please guide me if someone faced this problem.
Using creo 8
6 REPLIES 6
AFAIK reported functionality is hardcoded. You cannot change it.
Martin Hanák
Martin is right. You can't remove it.
https://www.ptc.com/en/support/article/CS110248
From the article - workarounds include changing the text color to be the same as the background color (still overlays on CAD models) or to use the temporary shade option (which is only temporary).
Hello @Karthik_1,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Thanks, I got partial answer that the tolerance table annotations cannot be deleted.
To be specific, I need to know whether the general tolerance table in the right bottom corner can be modified as per our customized requirement. ???
Default : x.x +- 0.1; x.xx +-0.01 ; x.xxx +-0.001 ; Ang +-0.5
Example custom required : x.x +- 0.2  ; x.xx +-0.025  x.xxx +-0.002 ; ANG +-0.2
StephenW
(To:Karthik_1)
Config.pro options:
These options apply when the part/assembly file are created. Changing these options will not change existing parts, only parts that are newly created.
linear_tol
angular_tol
