Hi all, I was working on independant mode of Mechanica, and using Capping Surface option to view the stresses inside the tube. But when I view with capping surface option, I see the rest of portion as wire frame, which is causing difficulty to observe the model. Is there any way to switch off the wire frame, so that I can see the stresses clearly?? Any help in this regard is appreciated. Thanks! Shekar
