Make cut through all the default
RobertH
As at least until Creo Parametric 11.0.6.0 when making a cut while using extrude or hole (and several other things that cut through geometry) the default is "Blind" and then with some random depth.
It would be far more confienient when this is "Through all" by default. This also solves that much engineers do not take the effort to set the depth to through all so the end of the cutout is somewhere outside the geometry (as shown below)
So make a config.pro option tho set the default to "Through all" for at least the cases shown below.
tbraxton
22-Sapphire I
(To:RobertH)
Check out feature presets which may address your particular issue if you upgrade to Creo 12.
Feature Presets
As of Creo 12.4, feature presets are supported for:
  • Hole
  • Extrude
  • Revolve
  • Round
  • Chamfer
  • Curve from Equation
Involute Development, LLC
Consulting Engineers
RobertH
(To:RobertH)
Sorry, I thought I was in the "Creo Parametric Ideas" section and as I did not found any related I thought it was new.
But it seems that there is already an Idea posted.
tbraxton
22-Sapphire I
(To:RobertH)
Feature Presets
  • Hole
  • Extrude
  • Revolve
  • Round
  • Chamfer
RobertH
(To:tbraxton)
Answers indirect the question but for me the problem is that we recently updated to Creo 11 and therefore do not have this functionality, updating is not that easy in a bigger company.
