Mapkey Examples. Developing a Github Repo of examples
BG_9869104
Mapkey examples for all.
Right now I am CREO 7.0.3.0 based so the mapkeys are based on that version.
Most mapkeys are mapped to the same key 'F9'. So you will need to change the mapping.
These are meant as examples to expand upon, edit, and combine to do tasks. I have tried to take these mapkeys down to the minimum/reasonable amount of code.
https://github.com/Ballganda/ptc_creo_config_mapkeys
Some of the mapkey code is commented so you can read what the code/script is doing. Here is an example with comments: https://github.com/Ballganda/ptc_creo_config_mapkeys/blob/main/creo7.0.3.0mapkeys/EditSketch
The comments can make the code look much longer than it really is.
Later I plan to keep going with example configs for different types of setups but that is way out there.
If you have an idea for a new mapkey check the idea list. If it is not on there suggest it.
https://github.com/Ballganda/ptc_creo_config_mapkeys/blob/main/mapkeyidealist
If you have a mapkey you want to share post it here in the forum.
If you find an error post it here.(I'm sure they are present)
Sources: I have read and researched mapkeys all over the web. I have taken that in as knowledge and then record mapkeys myself and manually edit.
So a thank you to everyone has posted documentation/information publicly. You have helped fill in the gap that PTC refuses to document.
0 REPLIES 0
