Mass Props Skeleton part
amedina
I got a user asking about mass properties in Wf4 M190. Specifically he sets
a skeleton part as suppressed or removed by a simplified rep however the
mass property mass does not change. Its clear to me that the mass of the
skeleton has a value. What is not clear is:
1) Is there a bug that prevents suppression of a squeleton from removing its
mass?
2) maybe the mass of a skeleton part is not counted in an assembly and I was
not aware of this until now? (this would explain why the mass does not
change if the skeleton is removed)
Any directives? tips? I'll try to figure it out today somehow.
regards,
Alfonso
There is no mo mass to a skeleton, as there is no solid geometry to have mass.
IIRC, this is intended functionality, as Skeleton parts are not intended to
have solid geometry, only datum planes, sketches, surfaces, axes, etc.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
dgschaefer
(To:amedina)
To clarify what others have said, a skeleton part is ignored when doing
mass property calculations. Typically, a skeleton is created with no
solid geometry; however there is nothing to prevent one from creating
solid geometry in a skeleton part. Regardless of solid geometry or not,
Pro/E ignores the mass of a skeleton in mass properties calcs.
This assumes that your skeleton is a true skeleton part and not a
standard part simply assembled first and used as a skeleton.
Doug Schaefer
LinkedIn
amedina
(To:amedina)
Great. Yeah I have no idea why the user added a solid to a skeleton. I'll
have to ask him to create a model for that so that he gets the correct mass.
thanks!
regards,
Alfonso
On Mon, Aug 8, 2011 at 12:39 PM, Doug Schaefer <
> mass property calculations. Typically, a skeleton is created with no solid
> geometry; however there is nothing to prevent one from creating solid
> geometry in a skeleton part. Regardless of solid geometry or not, Pro/E
> ignores the mass of a skeleton in mass properties calcs.****
> This assumes that your skeleton is a true skeleton part and not a standard
> part simply assembled first and used as a skeleton.****
> *Doug Schaefer
> *From:* aome dina [-]
