Coming from Solidworks to CREO I am hoping the following is possible, I cannot seem to find in the measure tool a means to measure perimter area. Screen shot example of what I'm trying to calculate:
It is not possible to select area on perimteter, is this possible in CREO?
I think you cannot measure an area of empty space. If it is planar curve then you have to create Fill surface and measure its area.
Hi Martin,
Thanks for the reply, I was hopeful this could be done via the measurement tool. Good to know I could use the Fill option.
Thanks, although it would be nice to have this in the model enviroment, it's not a problem to access via the sketch:
