Mechanism Design won't run on Creo Parametric 2.0
DamianCastillo
7-Bedrock
I have Mechanism Design and the license is updated to Creo Parametric 2.0
I tried adding the extension to different license packages that I have and it simply won't run. When I open the Application tab while working with an assembly, I see the option there but it says it's not compatible.
Any ideas?
ΜΟΛΩΝ ΛΑΒΕ
I thought Mechanism Design was part of the core application now. No separate license needed.
David Haigh
David,
For some reason I was thinking the same thing but I could not get it to
run. I tried adding one of my extensions to my license and I keep getting
a message that says it's not supported.
Damián Castillo | Engineering Systems Manager
Hensley Industries | 2108 Joe Field Road | Dallas, TX
- | 972-406-4788
www.hensleyind.com
