Hi all,
This is my first post on this community forum, so I apologize in advance if I'm missing anything!
I am working on an assembly where I have two parts that fit together with a small gap of 0.05mm. I am attempting to use the Mechanisms in Creo (which are apparently tedious to use in Creo compared to SW). I am using a 'Slider' constraint between two said components. I have attached a zip with part and assembly files.
The problem I am having is that despite with a 0.05mm gap, it seems like Creo thinks the parts are touching when they are not. What I mean by this is in the image below, you would think the surface highlighted in green would be flush with the one next to it. However, when I drag the components together, this is as close together as they can go!
I have no clue why this is happening. I assume it's probably some setting that I did not know to change. Any help would be appreciated!
I have tried changing the diameters around, and I've found that making the gap between the two larger results in me being able to drag the components closer to be considered flush with one another.
Thank you!
Hello @JiffiPop , @kdirth & @MartinHanak
Just illustrating what I documented above in little movie below for future reference if needed, and to hopefully grant a better understanding of what I meant.
Serge
The second part moves fine for me in the assembly supplied. The only thing that I see missing is setting some limits on the movement and a regen value if desired.
I am not sure what you are expecting. In the slider mechanism connection, the translation constraint does not snap to 0. You have to enter the desired position and set the movement limits.
I did leave limits and regen value out for the example. Below I have uploaded a video to clearly explain my issue. My question is why will the parts not drag together so they touch?
I can't see you video.
It took awhile to be approved. The video should be viewable now.
Ensure that you translation limits are correct. Also, if Set Zero Position has been pressed, 0 may not be at contact position.
The zero position is at the contact position. It gets stuck at around -3.35400 mm. The problem is not the limits, or the zero position. It seems rather that it is setup correctly, I just cannot drag it there. Perhaps this is a bug in Creo? It seems the only way to move it to 0.00000 mm is by manually inputting this number in the 'Translation Axis' portion of the slider constraint.
Without a model exhibiting the behavior, it is difficult to determine the issue. Additional parts before and after it in the model tree may be affecting it.
Hi, I uploaded a zip file in the original post that has the issue, and a video of the issue in the aforementioned assembly. It's not additional parts before and after in the model tree because it is an isolated incident that I even recreated in the assembly with only two components.
The only issue seems to be with the dragging feature only when using the mouse. I can type in to move it to position 0 mm, of course. However, this is really not ideal in terms of Creo's functionality.
Hello @JiffiPop
At the begining, starting without config.pro, I was unable to reproduce the issue. I nevertheless confirm that issue:
Background: When enabling advanced collisions, the models are somehow "meshed" to check when collision occurs. Here, your external diameter is 15.7863 inches whereas your internal one is15.7375 inches (very close to external therefore). In such demanding conditions:
Note: the default value 1000 is largely enough for the very large majority of use cases. We suggest to keep it as a default to avoid performance issues in larger assemblies, and just modfy it to 6000 if needed in some very specific situations (like this one).
Hope this helps to understand what occurred, why it occurred, and how to avoid this issue in the future.
Serge
Serge
Thank you, Serge! This is the solution! I appreciate your input! 🙂
