Wildfire 3.0 m250
I have created a simple mechanism (wall and floor at one hinge point) and created an open and close snapshot so I can show the two different positions on my drawing. I created the mechanismon a simple surface "Skeleton" (Floor and wall with the pivot axes).
I am receiving a "The connection "Connection_5" will be suppressed because of invalid constraint(s)." error when trying to open my walls on my upper level assembly.
My question is: How do I find out where this error is occurring so I can fix it?
When you run a Modelcheck you get errors and warnings and maybe what feature you are having problems so you can go resolve the error. With this error it does not tell you where to go to fix it.
Any help is appreciated
