I have a large assembly in Creo 8 with about 30 simplified reps. How can I figure out from the model tree to which simplified rep a certain component belongs, it could be a member in multiple simultaneously.
I realize you can create columns in the model tree representing the simplified rep, but having a large number of simpl. reps. makes this less practical.
Ideally, I'd like to right-click on the component and have the option see all involved simpl. reps.
Thanks.
Other than using the model tree to add columns for each rep, I don't know of any other way to do this.
A work-around would be to add the columns to the model tree, the save the model tree text and use excel to get the info you need. Not a quick/easy solution but excel provides much better tools for big data analysis.
