Dear all,
I am facing a typical problem with Pro/E wildfire 3.0 memory. I am generating a very big assembly using J/Link in non-graphic mode.
Once the application exits, the generated assembly is saved in a folder where i can open assembly to view, by using usual procedure
of Pro/E. When i am trying to do so, sometimes Pro/E is opening the model based on the sub-assemblies being added, sometimes it's not (if subassemblies added are more). Further, i am also getting error such as "insufficient memory".
My system is 64 bit, 8GB RAM, HP-XW6400 series PC. I know this is
a memory issue with Pro/E. Can anyone guide regarding memory management for Pro/E WF 3.0.
Further, i want to know whether PTC has different versions of Pro/E wildfire 3.0 for 32 bit and 64 bit systems.
Any suggestions are very valuable.
Amar Vemanaboyina,
Team Leader Programming,
Idolafori Design Workd Ltd,
Jubilee Hills,
Hyderabad.
