Merge walls Creo 3.0
ptc-5472289
6-Contributor
I am looking for some help with merge walls tool. I have a tube, which needs to be cut on tube laser. Due to previous design, we haven't used tube as starting point and part was designed in sheetmetal.
Is there a way to merge surfaces so line indicated below is no longer visible?
4 REPLIES 4
StephenW
(To:ptc-5472289)
Is your sketch to create the sheet metal part broken at that point? If it's still sheetmetal and was created to start/stop at that point, you'll be stuck with that line.
Hard to say from a picture.
If you drag the "End of Part" all the way up, and then down again (one feature at a time), when is that line created?
So if i understood the question right, you need to make a laser cut on two perpendicular faces of a rectangular extruded tube. Right?
KQD
(To:ptc-5472289)
Can you not just create a sketch with a rectangle on the end of the tube and extrude it to the other end to "fill in" the part?
