Merging Part Parameter in Table
MC_10388914
3-Newcomer
In some of our assemblies we use varying lengths of the same item, defined in a family table. We have been able to drive a parameter by the length of the instances no problem, and this places the different lengths of the items as separate lines in the BOM as desired.
However, we would like to have a separate table which shows the total required length of that item. For example if we use two 100mm and one 200m strip of the same tape we require a table to display the part number for the tape and the total length of 400mm. In some assemblies we use also use multiple kinds of tape which we would like to display all in one table.
Is there a way to combine parameters between parts with the same name and description and display as a single item in a table?
thanks
