I am having trouble exporting a drawing into .dwg format and getting the drawing scale to be correct. We draw all of our parts in English units, and I need to find an automated way to convert the files to milimeters, and export them to Autocad. When I change the part units to mm the drawing looks correct. It even looks correct in autocad, but when I interrogate the drawing in autocad the entities are still in english units. For example a 25.4mm block will have a 25.4mm dinemsion that was exported from Pro, but it will measure 1 in autocad. Any help would be appreciated.
