Missing Top,Front,Right datum names
ptc-5153821
Anyone know why my principal datum planes won't display as Top, Front, and Right but instead show up as DTM1, DTM2, and DTM3?
Also, how do I display datums (planes, points, etc.) in the model browser in Assembly mode?
Thanks.
[Using Pro/E Wildfire 4.0]
By default, if you create an empty part and then create the default datum planes, they get the names DT!, DTM2 & DTM3. If you want them named, you need to:
  1. Create a template part
  2. Create the planes
  3. Name them
  4. Save it to your start part or template folder.
  5. Set the config option 'start_model_dir' to point to your template folder
  6. Pick your template when you create a new part.
LinkedIn
  3. Name them
LinkedIn
