Model Nominal Dimensions Change Unexpectedly
BobCondra
I have a sketch that has the diameter controlled by the left circle in the sketch. I want this dimension to be now controlled by the right circle in the sketch. When I change the reference dimension on the right circle to “strong”, the dimension actually changes from .1505 to .151. Take a look at the pictures.
[cid:image002.jpg@01CF9441.42A294D0]
[cid:image004.jpg@01CF9441.42A294D0]
[cid:image006.jpg@01CF9441.42A294D0]
What can I do to prevent this from incorrectly rounding the dimension to a different value?
If I have four1/16” dimensions next to each other, and then if they get inadvertently rounded (without me catching the error), my fourth modeled feature is now off by .002” – severely affecting the design intent.
Bob
Bob Condra
Mechanical Engineer
Trijicon, Inc.
248-960-7700 Ext.1147
49385 Shafer Avenue | P.O. Box 930059
Wixom, Michigan 48393 US
- | www.trijicon.com
1 REPLY 1
DeanLong
(To:BobCondra)
Check Config option - default_dec_places
Also,look atFile, Options under "Sketcher"... "number of decimal places for dimensions"
It appears as though you arerounding up to a set 2 place dim once it is made strong.
