Hello @Phil_Cardozo
This is unfortunately not part of ModelCHECK capabiltities for the reason explanied here below:
In other words, UNITS_LENGTH can be used to CHECK but not to UPDATE a given length unit in a model checked. You may want to create a new idea here (did not find any reported so far i this direction), but if it will be implemented, this will need also to consider HOW this update will be done in an automatic way (and if this can be controlled). Because as you probably know, when changing units of a given model, you have the choice to Interpret or Convert the existing dimensions (producing a very different outcome). Therefore, if update process via ModelCHECK will be possiblle (via an enhancement) in the future, it should also ideally give the possibility to configure if the update should be done in Interpret or Convert logic.
Serge
Thank you, Serge.
The detailed response is helpful.
Phil
