I have slow problems with the ModelChek.
The slowness is due to the action of the antivirus.
I would like to be able to exclude ModelCheck from the antivirus action by excluding its execution file or the folder where it is contained, but I have not found one or the other.
Could you help me?
Thank you.
P.S. I use Creo 9.0.2.0
ModelCHECK runtime files are stored in:
C:\Users\<Your Username>\AppData\Roaming\PTC\…
Add this folder to your antivirus to skip.
Thank you MIchael, i'll try it.
