Modeling PE under Vista-64 and Intel graphic driver
ptc-2382303
Is there a special version planned for Vista-64? I have installed it using the standard setup under Vista-64 and no problem occurs. I have some problem with the display but I think this is related to opengl driver bugs. I have an Intel integrated chipset (GM 965) and the opengl driver seems to be rotten!
Not applicable
(To:ptc-2382303)
I am not aware of any plans for a Vista-64 version. AFAIK, the 32-bit versions of Modeling PE run just fine on 64-bit operating systems. Also, with the current limit of 60 parts in the free version, a 64-bit version isn't really needed anyway. The Intel integrated graphics chipsets (or rather, their associated drivers) are unfortunately notorious for causing problems in Modeling PE. You can find some previous discussions at <ul> <li> http://apps.cocreate.com/OneSpaceModelingPE/Secure/Forum/forums/thread-view.asp?tid=362 <li> http://cocreateusers.org/forum/showthread.php?t=6785 <li> http://apps.cocreate.com/OneSpaceModelingPE/Secure/Forum/forums/thread-view.asp?tid=372 </ul> A workaround is described in the second discussion in the list above.
ptc-2382303
(To:)
Great, the environnement variable is solving the issue. Thanks.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
