As an user. I would like to configure what information is displayed on the Activate Window dropdown menu on the top left, so I can have enough information there to be able to imediately find the window im looking for.
Currently, when you click on the activate window dropdown menu, it only shows the filename. It would be very usefull to be able to configure what info is displayed there,
We use a description parameter on our files. It would be great to see, for example, " Partnumber - Description" on the dropdown.
Example: Today, on the dropdown:
Part1.ASM
Part2.ASM
Part3.PRT
Part4PRT
Part5.PRT
Part6...
then you think " I want to see the "plate....which one is that again?" and then you proceed to probably click on the wrong one a couple of times
after the change:
Part1.ASM - Plate Kit
Part2.ASM - Plate Assembly
Part3.PRT - Bolt
Part4PRT - Plate
Part5.PRT - Washer
Part6.....
Then you imediately click on the window you need.
Is there a way to do this? If not, colud we have it? Pleeeeease.
thx
Are these windows that you already have open and you just want to activate them?
If so, could you just Alt-Tab to the open window instead. Shift-Alt-Tab goes backwards. You can also us the up and down arrows to quick jump down rows of open windows.
Sometimes I max my number of window allowed open besides other things like Word, Excel, Outlook, Chrome. I find this fairly efficient.
yes
I rarely have only Creo windows open. Alt-tab will bring up browsers, notes, IMs, windows explorer, etc.
Also, if I just jump windows, I will still need to activate them. I do not have auto-activate current window on bc I use dual monitos and sometimes some windows will have very busy models, so I rather not activate them unless i really need to.
you cannot modify activate window dropdown menu.
Solution: Add description name into filename.
That solution wont do. We will not change 1000s of parts filenames. Its a corporate thing.
Also, the description contains blank spaces. It would be a mess.
Can we input this as a quality of life improvement?
Enhancement requests are here: https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
Feel free to put one. I would suggest that you don't expect much...
Read thru some, you will see 1000's of good ideas that never get anywhere...that's why others are suggesting work-arounds, it's likely going to be your only viable solution.
