I'm curious if anyone has links to any more detailed tutorials or use cases on motion skeletons or any personal experiences they can share. I've seen a few YouTube videos as well as the eLearning topics in the section on AAX. I'm interested in more info, however.
Some questions I have:
The examples I've seen are simple, one cylinder engines which illustrates the power of the concept, but doesn't give much insight on integrating it within a more complex assembly where I need to control outer surface contours, part lines, screw boss positions and motion in more than one plane.
How are people using them in the real world?
Doug, I am not sure if it adds more to youtube's that you saw, but just in case :
http://www.e-cognition.net/pages/MotionSkel.html
I had seen the e-cognition page as well as a couple of YouTube videos. The videos I found had no sound, so there was no elaboration on what was happening.
Your short explanation has shed more light on the motion skeleton theory than the PTCLearning class or any of the videos I've found. It looks like a powerful feature that is poorly documented.
sorry, but i have had the same problem for many years.
the ptc support is too light to allow a powerful use of complicated motion skeletons.
i have sent a question to ptc communiity and no answer.
i think that motion skeleton by PTC is a teaching function ( look at precision LMS ) which is not used by the designers or very rarely.
we can't work with sub assemblies easily, only parts : this is a great problem for a designer.
the automatic recognition of the connections is not successful.
you have to use personal tools ....
regards
Fguertin
