Multi sheet drawing always goes to last sheet on save
mashton-2
Using CREO 10 .0.4.0 When we save a drawing that has several sheets it always goes to the last sheet. This seems counterintuitive to us and my users would very much prefer to have the first sheet or the current sheet displayed once the save has happened.
I looked for a config option but could only find "Default open drawing sheet"  which controls whether the 1st sheet or the last open sheet is displayed on opening a drawing.
Is this just CREO 10 behaviour or is there a way to set CREO so that it doesn't default to the last sheet on saving a multi sheet drawing?
2 REPLIES 2
StephenW
(To:mashton-2)
I use creo 8 for production work. I have access to Creo + (aka creo 12) also.
I tested on both and I don't see what you are seeing.
I would suggest you try removing all your settings, (config.pro/config.sup) temporarily (OOTB creo) and relaunch creo to see if you have a setting that affects that.
mashton-2
(To:StephenW)
Thanks Stephen
I used to have control over the config.sup so could have done that in the past but now everything is centralised through IT so it isn't so easy I am raising it with them though.
At least what you have shown is that it must be controlled by a setting somewhere.
