I have a 20 conductor cable that goes from an over molded connector to a board mount connector
the cable is stripped at a strain relief, and the individual wires come out of the cable over to the board mount connector
I have the network going from where the strain relief is up to the overmolded connector
I have my logic setup but it just will not automatically route the wire:
! Components and connectors
NEW CONNECTOR J1
PARAMETER MODEL_NAME 2A_SWITCH_DSUB_CABLE_ASSY
PARAMETER NUM_OF_PINS 160
PARAMETER GENDER FEMALE
PIN A1
PARAMETER ENTRY_PORT PINA1
PARAMETER GROUPING ROUND
PARAMETER INTERNAL_LEN 0
PIN A2
PARAMETER ENTRY_PORT PINA2
NEW CONNECTOR J2
PARAMETER MODEL_NAME CONN_VPC_QUADRAPADDLE_510150115
PARAMETER NUM_OF_PINS 192
PIN A1
PIN A2
! Wires and cables
NEW CABLE P1_BUNDLE UL2517_20C-24AWG_SH
ATTACH J1 "" J2 P1
CONDUCTOR 1
ATTACH J1 D5 J2 A29
CONDUCTOR 2
ATTACH J1 D6 J2 B29
CONDUCTOR 3
Any ideas?
Im just about to give up and make discrete wires with a sheath
Try setting the cable attachments to "" "" "" "", perhaps?
I tried that but it didnt work, I ended up just making it with discrete wires and a sheath
thanks though
