Multiple Intralink users on one PC?
proe_dave
I need some suggestions on how to set up a PC for multiple intralink users. One is part time, the other a consultant.
Each user has their own log in. I'd like each user to have their own .proi folder and Local.ddb.
Any suggestions?
Dave Haigh
Easy Day!
We use the default location for installing Pro/Intralink
3.4(C:\ptc\proiclient3.4), and also put all other PTC products under the
C:\PTC folder, C:\PTC\proeWildfire2.0, C:\PTC\mechWildfire2.0, etc...This is
modified in each of the installations.
For security reasons we setup a USER folder on the D:\ drive if possible.
Under Windows Preferences of the Pro/I installation we set the Startup
Directory to D:\USER\%USERNAME%. %USERNAME% is a system variable which is
the person logged in. You will have to create a file for each user, and also
delete the system created D:\USER\%USERNAME%.(Yes it actually creates the
folder!) Under each username they will have their .proi folder. This can be
done from ~\proiclient3.4\Bin\ptcsetup.bat.
You will have to change the Pro/E Startup Directory in Windows Preferences
to D:\USER\%USERNAME%, and also for PTC OLE Server Startup Directory & Start
Search Directory. You must also change the Structural & Thermal Simulation
Startup Directory in Windows Preferences to D:\USER\%USERNAME%. Both of
these applications can be modified in their respective Bin\ptcsetup.bat
files.
Oh! You will also have to set your PDM_LDB_PATH to D:\USER\%USERNAME%.
This also works on the C:\ drive, but is more secure on the D:\.
Hope this helps,
Tony Stevens
ArvinMeritor CVS
CAD/CAE Analyst
