Hi - I'm new to mechanisms contstraints, but getting there.
I have a problem where I have a door handle that can be depressed through a limited arc. There is also a button on the handle which can be depressed. I have set up the constraints for both of these pieces, but the problem is when I drag the button to the different positions on screen, the whole handle moves (through the arc) on the screen too. How do I set up so that I can drag the button to different on/off positions but I don't change the angle of the handle? Each piece should be independently movable without moving any other part.
Counter to that, I can move the handle through the arc and the button stays in the position and doesn't move, so i know it can be done
Thanks..
Unfortunately that is how mechanism moves when you drag parts on the screen.
Check out this discussion - Freeze-mechanism-joints and this Idea - enable-disable-mechanism-constraints
Ugh - that really is so annoying for me. Thanks for the links - I'll check them out and see if they help.
Thanks again..
