Need help in figuring out parts getting visually corrupted
- May 30, 2025
- 1 reply
- 894 views
1) I have had a problem where the parts and sometimes assemblies get visually "corrupted". If it happens in parts it is still doable to work around it If I ignore it, as only the visual image gets distorted but I can still work with the part as normal (I can rotate, extrude, and everything normally). Things get tricky when a whole assembly starts to act this way, and I cant really ignore it.
I suspect that is occurs the most when I open a part from the assembly and start working with it, but I am not very sure why.
I am not very knowledgeable of computers but these are my laptop specifications:
processor: 11th Gen Intel(R) Core(TM) i5-1135G7 2.40GHz 2.42 GHz
RAM: 16.0 GB
Graphics: Intel(R) Iris(R) Xe Graphics
Creo: Creo Parametric ver9
2)Another college of mine has a problem where Creo straight up just crashes and closes when it becomes a little heavy. The most we do is drawings and assemblies and it crashes for him. We rarely do simulations. We suspect that it is because his low memory, but if there is a known reason for this it would be great to know.
CPU: Core i5-10210U 1.6GHz SSD:256GB
Memory: 8GB
Graphics: Intel UHD graphics
Thankyou in advance.
