Need help with Creo 2.0
dcoin
Hello everybody,
I am trying to do my hw, but I got stuck at the small circle in the red areas. So, Can you guys please show me how to make 5 circles that their angles of distances from each other are the same?
I don't remember what my professor did, but he said about 360/5????
I can do the other ways, but it will take a lot of time.
Thank you all
BenLoosli
(To:dcoin)
You build a rotational pattern and for the angle you enter 360/5. You could then modify the 5 to the d# that has the value of 5. That will keep the angle parametric.
7 REPLIES 7
BenLoosli
(To:dcoin)
rcook
(To:dcoin)
Put in one hole and then pattern it. If you want to follow the design intent of the sketch, then place the first hole as a type "Diameter". Then pattern the hole using an axis pattern that references the center axis of the part. 5 pattern members, equally spaced around 360 degrees. Screenshot is from Creo 3, but it's the same in Creo 2.
dcoin
(To:dcoin)
I don't really like to make another post, so I post it here D
Can anybody please show me where I can find the dome mode????
I look for everywhere, but I can't find it.
Thank you
StephenW
(To:dcoin)
In the top right corner, there is a magnifying glass for search. Click the glass then type dome in the box, it will take you to the dome command.
I personally would simply add a revolved arc on your part though.
I would also suggest in your future posts to start new ones with titles that are more descriptive of your question. Most everyone asking questions needs help with Creo X.0 so a better title would probably help you get better responses and allow you to mark correct answers on the post so future users can search and find answers easier.
dcoin
(To:StephenW)
I am practicing for a midterm, after I am done with everything, I don't really know how to make the bracket look like in picture. Please help me!!!
Thank you
RonSt.Pierre
(To:dcoin)
sorry, bout ready to head home...
google: cutting sections with a curve or sketch.
You might find a video on youtube
dcoin
(To:dcoin)
Oh i get it, so I only need to cut it with a retangular.
Thank you so much, I totally didn't think about it
