I want to know whether we can use the sketches saved in session or not.
Do you mean saving sketch externally and use in other part or so?
If this is what you are looking, you can save sketch as section file (.sec) and use / import in other part sketches.
When you create a sketch, the sketch (.sec) will be added to your session memory. You can see this if you look at the object list (File>Manage Session> Object List). You can reuse the sketch in another part by performing the following steps:
If you close the file and erase memory, the sketch (.sec) will also be erased. Reopening the file that contains the sketch does not add the sketch (.sec) back into memory. So, if you erase memory, the steps from above no longer work. You would need to do one of the following:
Ty
