Nest smoke alarm: How to create the "fibonacci-like" hole-pattern
ptc-4890452
1-Newbie
I just came across this Nest smoke alarm, and got curious about the pattern on the front: https://nest.com/blog/2013/10/08/meet-the-nest-protect-smoke-and-co-alarm/
Is it possible to somehow through one or more pattern features to create something like on the attached picture? I can't crack it myself. Help is appreciated
https://d2pupd7a6asjpt.cloudfront.net/blog/images/2013-10-08/nest_protect_smoke_co_alarm.jpg
Interesting patterns came up when trying to do this without the reference. For the most part, I got the jest of how to make sure it could be mirrored. I used the arc to get a good pattern and the linear pattern with a "twist" for hole sizing and extrusion.
Full version of Creo 2.0 attached (minus the underlay image so it doesn't mess anyone up).
43 REPLIES 43
This can be done with a sketch and patterned.
It looks like it follows a simple arc increasing diameters.
You can just 2 guide arcs and make the holes tangent.
Ah, I see.
My mind was stuck on the fill pattern, but I can see how it is possible with a sketch and a pattern around the center axis. I'll give it a try.
Thanks.
Quick and dirty test:
It needs some adjustment to look more like the pattern on the nest, but it's definitly possible. Thanks for the help.
DavorGranic
(To:ptc-4890452)
Maybe:
pattern1:Arc with holes increasing in size as they go outward
pattern2:revolve pattern 1
you could create that in less than 5 minutes with grasshopper3D
heres a similar example done in it.http://bit.ly/1kfaVgv
Isn't it basically offset circles from the corners of a square with points on the intersections?
Its not fibronacci... more like spirograph with control of a common web thickness.
It wouldn't be hard to duplicate by using the image as an underlay and finding the right guide arcs.
It is a very nice industrial design application.
Esben, looking at yours, it is "drifting"? I was thinking you need to look at the mirror to see if it overlays correctly in both directions. I haven't tried it yet but I may give it a shot just for fun.
Here's a more examples in Grasshopper with a grab of how you would do it in there. You might be able to look at the nodes and extract an idea of how to do it. I could give you more info if you have any questions, I'd give a detailed response now, but I don't have time.
http://bit.ly/1bKgPH9
http://bit.ly/1kfjuId
Here is a great reference with interactive examples. Probably your best bet.
http://bit.ly/1kfjHLp
Patriot_1776
(To:TomD.inPDX)
Agreed. I'm actually looking for a Spirograph for my daughter for X-mas.
Awesome gift idea, Frank! Really cool to see they're still available in stores.
The Nest thermostats and alarm systems actually came up in one of our meetings last week, fun coincidence this gang would bring it up here in PTC Community.
Inoram
(To:ryankelley)
Except for price. I just put 7 new smoke detectors in my house. Unless these have remote modules or something I didn't see. $130 x 7 is fairly expensive for smokes.
Oh, I meant the Spirograph, great value at $14.99 for a full set at your local Target.
Agreed Matt. The Nest was brought up in the context of a conversation about the "internet of things" (further reading if you're intetrested), where we're seeing a big shift toward internet-connected home products (think thermostats, smart TVs, and small appliances). Nest is on the bleeding edge of this trend, so hopefully the price will come down over time to the point where your next purchase decision won't be prohibited by cost.
Inoram
(To:ryankelley)
OH sorry, mis-read.
You can still buy those? My kids would love that, too.
Dale_Rosema
(To:Inoram)
You sure there's not an app for that?
Inoram
(To:Dale_Rosema)
I was thinking that.
And then I looked.
Appears to be a bunch of them.
This is what I came up with so far. The mirror overaly is not resolved yet but I have an idea. One of the difficulties is the 84/360. But that is how it would be resolved. In this case, I just snuck up on it by checking a mirror circle in the sketch. You should be able to constrain it to be perfect.
As for constant webbing and such, it will require significant sketch control but nothing that can't be done.
Inoram
(To:TomD.inPDX)
AH, you were posting at the same time Antonius. I think it's even easier, though.
TomD.inPDX
(To:Inoram)
At least it is simpler than the golf ball was
Inoram
(To:TomD.inPDX)
When I saw this I first agreed with basically what Antonius and Davor said. But then I went to Google images and found a larger picture, and stared at that some more. And now I realize it's even simpler. no arcs, no nothing like that.
I will sketch on it a bit, and show what I think it is, in a little while.
TomD.inPDX
(To:Inoram)
This pair?
The arc actually helps this in some respects but yes, these are the two key elements.
Inoram
(To:TomD.inPDX)
yeah, to me, that's it, that's the whole feature. The rest is like a semi-optical illusion.
TomD.inPDX
(To:Inoram)
I went through the "great circles" for each of the hole series and they are not expanding at a specific rate. On a graph, they actually curve. In my sample from 6 to 7 back to 6.5. The photography is part of the distortion, but it may not be linear either. That "true circle" effect is done purposefully. That is why that inner pattern, the 1st one seems "odd".
This is what a true linear interpretation looks like and the constant arc disappears.
Inoram
(To:TomD.inPDX)
This is the other picture I found.
Inoram
(To:TomD.inPDX)
Inoram
(To:TomD.inPDX)
Patriot_1776
(To:Inoram)
Kewl!
Patriot_1776
(To:TomD.inPDX)
Nice!
This has quickly become my favorite discussion in the Creo community since starting at PTC. Really impressive work, guys.
Patriot_1776
(To:ryankelley)
Pshaw, you shoulda see Antonius's golf ball!
