New drawing format and template
BenLoosli
I have renamed our existing part drawing template and format and have added a BOM table, so I am using a single template for parts and assemblies. The engineer only needs to delete the BOM if it is a part file and a material table if it is an assembly.
However, when I create a new drawing and use the new template, the BOM does not populate automatically. If I add the BOM table to the drawing, it will populate 'manually'. What could be causing this to function to not work automatically from the drawing template?
Creo 2 m220
Windchill 10.0 m040
TomU
(To:BenLoosli)
Was the template in "template mode" when the repeat region was added to it?
(Might be located somewhere else in Creo 2.)
3 REPLIES 3
TomU
(To:BenLoosli)
BenLoosli
(To:TomU)
The repeat region BOM table and other tables are added at the format level then the format is added to the drawing template.
I will try to replace the format with the drawing set to template mode and see what happens.
BenLoosli
(To:BenLoosli)
Adding the format to the drawing while in template mode did the trick.
Thanks, Tom.
