New projected drawing view WITHOUT all the annotations being displayed
Pkoren
7-Bedrock
I cannot find the setting, I believe in the DTL to change the default behavior for new projected views.  What we want is for the view to come in WITHOUT any of the annotations displayed.  I have seen this behavior in the past (at different company/installations) but we see all the annotations that are in the acceptable orientation display and we are forced to do a bunch of cleanup work.  We would like to eliminate that.
thanks in advance!
6 REPLIES 6
MartinHanak
(To:Pkoren)
please provide more details, i.e.:
  • pictures of model and drawing
  • Creo files for testing purposes
Martin Hanák
StephenW
(To:Pkoren)
config.pro option available on Release: Creo Parametric 7.0.4.0 and UP hopefully
 auto_erase_set_datum_planes  YES
see
https://support.ptc.com/help/creo/creo_pma/r7.0/usascii/#page/whats_new_pma/drw-auto_erase_set_datum_planes.html#
Pkoren
7-Bedrock
(To:StephenW)
Thanks, tried that with the example above.  Doesn't change the behavior.  We are on CREO 8.0, so well past "set datums".
Pkoren
7-Bedrock
(To:Pkoren)
What we have is something like this, yes, this is a meaningless model generated just for show here:
The right side view is a NEW projected view from the left one all in a drawing...
What we is for that right view to come in WITHOUT any of the annotations shown.   (And yes, all those are annotations I created for this example...)
kdirth
(To:Pkoren)
I have not seen this behavior before.
Sounds like something that could be in the drawing details (dtl file).  Export a DTL file and share if possible or send your example.
A copy of your config.pro could also be helpful.
MartinHanak
(To:Pkoren)
please prepare Creo test data, pack them into zip file and upload this zip file.
Without Creo data, it's almost impossible to guess what's going on with you.
Martin Hanák
