New system to replace defective one for WF3
jjakubos
Current machine specs....
T3500 Specs
Specifications:
PC Expansion Bays
Number of 5.25in External Expansion Bays
2
Number of 3.5in Internal Expansion Bays
2
Memory
Number of DIMM Slots
4
Maximum memory (RAM)
24GB
RAM Type
DDR3
Installed memory (RAM)
4 GB
Motherboard
SATA RAID Levels Supported
10, 0, 1, 5
Maximum Number of Processors Supported
1
RAID Supported
Yes
Sound Card on Motherboard
Yes
Chipset
Intel X58
Hard Drive
Interface
SATA2
Hard Drive Type
Internal
Wired Connections
Wired Terminals / Ports
Serial, External SATA, DVI Output, USB 2.0, Microphone Jack , RJ45, PS/2 Keyboard, PS/2 Mouse, Headphone Jack
Input Devices
Input Devices
Mouse, Keyboard
Power Options
Power Supply
AC Power
Maximum Power Capacity (Watts)
525
PC Expansion Slots
Number of PCI Slots
2
Expansion Slots
PCI Express x16, PCI Express x4, PCI
Number of PCI Express Slots
2
Number of PCI Express x16 Slots
2
Processor
Processor Speed
2.6 Ghz
Processor
Intel Xeon
PCs
PC Case Form Factor
Mini Tower
PC User Suitability
Business
General
Height (mm)
447
Weight (g)
1770
Width (mm)
172
Available Colours
Silver, Black
Length (mm)
468
Graphics Card
Graphics Card Interface
PCI Express x16
Audio & Speakers
Number of speakers
1
Software
Operating Systems
Windows Vista Ultimate
Media
Card Reader
No
Jim Jakubos
Rexair LLC
Project Engineer
bgruman
(To:jjakubos)
Jim, I'd be happy to help answer your question, but I'm going to need
more hardware details to do it.
Current machine specs:
I don't see a listing for the actual hard drive. Size (GB), and Speed
(RPM)?
I don't see a listing for the actual Video Card. Brand, or Model?
Video Card: Your listing specs for a Quadro 2000... Is this in your
current machine, or is this in the new one?
New machine specs:
This is Dell's general listing of the possible min and max options for the
system. What are the "actual" parts that you are going to choose to put in
the machine?
However, In general terms... You are trading up from a T3500, to a
T3600. So, in general, the answer is Yes, you should be able to come up
with a comparable hardware spec list that will perform as good or maybe
better than you current one.
If you'd like to talk in more detail, you can contact me directly. I'll
be happy to help.
Good Luck
Bernie
Bernie Gruman
Owner / Designer / Builder
www.GrumanCreations.com
563-586-2056 (office)
