Hello all, I'm just getting started with piping. I found a tutorial through the help button in Creo, but I can't get back to it for some reason. I managed to make the routing that I want, and I'm pretty comfortable with the interface, but I assume that I am doing something wrong. All the pipe routes appear as lines, and not 3D pipe. I created the Line Stock and checked the dimensions, but maybe I did something wrong.
This is a series of 16" and 24" piping coming off a suction and discharge header.
If you can tell from the screenshot, please let me know what I'm doing wrong.
Thanks in advance.
Never mind. I figured it out.
"Display thick pipes on the toolbar".
