No Hidden line detail for swept blends
nhanratty
All
Not sure if this is 'intended functionality' but attached is a drawing view of a model created using a thin walled swept blend.
The view has been set to No Hidden but as you can see I am still able to view a lot of the hidden edges.
Any idea why this is the case?
Creo 2.0 m120
Neal
4 REPLIES 4
TomU
(To:nhanratty)
Do you have "Fast HLR" enabled? This can cause issues...
[cid:image002.jpg@01CFD8BA.22BE5790]
Thanks Tom
I have tried that option on and off but it doesn't make a difference.
The strange thing is the resultant PDF is created correctly without the hidden lines.
Neal Hanratty
Engineering Systems and Standards Manager
Terex Materials Processing Group
T +44 (0)28 8241 8769
F +44 (0)28 8225 2740
M +44 (0)75 3495 2739
E neal.hanratty@terex.com<">mailto:neal.hanratty@terex.com>
Just a quick update...thought if I made it completely solid and then shelled it I might get a better result, but no joy.
The attached image is completely solid part....this must be a bug?
All
For those that are interested I think I have found the problem...we have a config.pro option 'mesh_spline_surf' set to yes.
When I changed this to no it corrected the views.
