I have recently updated to Creo 6.0.4 (from 5) and and I can't get to properly write notes with boxed text. I want to represent a geometric tolerance in a text note. Attached picture Note - boxed text Creo5.png shows a typical note I would write rather easily in Creo 5. The way I would do this in Creo 5 was to :
Not as user-friendly as you would hope, but it would work.
Now, when I perform the same steps in Creo 6, it shows me the result I want while I type, but the various boxes are merged as soon as I click outside the text zone. Picture Note - failed boxed text Creo6.png shows the unwanted result.
That seems like a bug, doesn't it? Does anyone know a way around?
Mathieu
Note sure of how to do it in the "WYSIWYG" box of typing, but in Creo 4.0, I right click on the text and open the properties. Then I would type:
@[symbol@]@[.025@]@[A@]@[B@]@[C@]
OMG! That code-style way of typing still works in the Note Property dialog box?! Thanks! I thought it had disappeared when Creo introduced the possibility to edit text directly in the main window, along with the toolbars and the Box button.
Thank you very much!
