"Eric Mills" wrote:
Nick We usually leave a large space in the note and place a standard surface finish symbol in the blank location. It is not directly inserted into note. Now you could make a symbol that had the note and the surface finish if you are going to use it more than once. Regards Eric
"Eric Mills" wrote:
Nick With the surface finish symbol highlighted go to edit/group/relate to object. That will tie them together. Eric
