O-RING slot
MASSBAY14
O-RING slot
Any ideas on how to creat an O-ring slot on  part.\?
thanks
6 REPLIES 6
What is the problem?
Create the section view and do an angular pull with remove material.
Thanks for the answer.
how can I insert oring slot around the part shows on the picture.I tried the steps you listed but didn't work for me.CYL1.JPG
highway45
(To:MASSBAY14)
You have to put the workplane into the center of the part.
Instead of this, you could put a workplane at one plane face, then move it to the o-ring position and then remove the material by vertical pull.
SolidDesigner-20.5 + PE8 + PhoenixPDM + Solidworks + Blender
didn't work.it will cut the part in half.
do I have to drow a circel in the work plane thane move it to the spot where i need the slot?
Thanks for your help.
is it that what you want?
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
Use the "WP on axis" command to create a workplane with the U-axis coincident with the axis of your cylinder. Then draw a profile on the workplane for the O-ring groove. Use Pull Angular to remove the material, specifying either the cylinder or the WP U-axis as the axis of rotation. (You don't need to enter an angle-it will default to 360 degrees even though the field is yellow, which normally indicates that you need to fill in a value.)
