Open ProE Assembly as Light Weight model
ptc-3191571
I have a assembly with almost 1K components, my system has 4 GB of RAM.When I open this assembly in ProE sometimes ProE becomes non-responsive or other process starts executing slowly.
I am working on WF 5.0 M060.
So I would like to know is there any way to open ProE assembly as a light weight using which I would able to work a bit faster?
5 REPLIES 5
I would suggest reading up on simplified reps in the PTC Knowledgebase
(support) section. There are many, many options you can leverage to work
with light weight, simplified assemblies.
I am assuming you own your seat and pay maintenance.
Tim McLellan
Mobius Innovation and Development, Inc.
mlocascio
(To:ptc-3191571)
Simplified Reps or Shrink-Wrap or Copy Geometry.you have a few different
options based on what you're actually trying to do.
Michael P. Locascio
What is Shrink-Wrap or Copy Geometry?
can you please elaborate more?
jellis
(To:ptc-3191571)
A Shrinkwrap collects the geometry based on a quality setting and creates a surface centric model. If you create a Shrinkwrap from an assembly you will get a lightweight prt file. With this, there is little option for modifications. If you desire is to continue editing components or developing the design then Simplified Reps using On-Demand features is your likely path.
However, if you simply want to have a complete assembly for viewing/presentation then perhaps usnig ProductViewmight be beneficial? Save your ProE assembly out of ProE as a ProductView.pvz file. Erase the assembly model from session. File, Open the saved .pvz file and ProE will translate .pvz into a model of faceted components. This new ProE assembly will be light weight.The only edits permitted would be Deleting and/or coloring of the translatedcomponents and adding additional ProE components giving you a mix of light weight and heavy models.
Regards, Jim
Thanks All for replies..
Information I received was very helpful.
