Hello all,
I recently started working with Creo Parametric 3.0 and after playing with it for a while I've come across a problem I can't seem to fix. I would create a manufacturing assembly program and drawing. I then show the tool paths so the machinist know what's going on. However, if I ever open that drawing again it will crash immediately. But if I don't show the tool paths it will open with ease. Or if I open the manufacturing assembly first and then open the drawing it also works fine. What is going on? Is it something to do with the graphics card?
I have seen this forum discussion (How to Fix "Fatal Error Encountered. A traceback has been written") that explains how to fix the problem I am having but I do exactly what the directions say and still no luck.
This is the error that pops up when trying to open the drawing:
The traceback.log is also attached.
Any help is appreciated.
Thank you,
Brian
please report the problem to PTC Support.
MH
