Security Alert Log4j Security Vulnerability. Click here to know more.
Opening drawing from part model
nsfreund
Pro-Gurus,
I had a Solidworks guy here ask me if there is a way to open the drawing
in which a part is used in from the model itself? This is obviously
assuming you have the part/assembly and the drawing in your workspace. I
know you can do the inverse of opening the current model that is in a
drawing..the current model will automatically highlight when you select
File>Open while the drawing is up.
(Wildfire 3.0 & Intralink 3.4)
Nick
We use Start Up Tools to perform this action. There are other Toolkit applications that do this as well, but both options only work if the drawing name is the same as the part name. I.E. 12345.prt and 12345.drw
Hi
We uses a VB script to achieve this. Feel free to use it, but no support and no guaranties that it works for you.
It's made for Creo Parametric, currently using version 5.
Regards Mats
Trebla
(To:nsfreund)
Hi nsfreund,
You can do it also using a mapkey, look at this thread, a post from @lhoogeveen of 01-04-2019.
But it could be that it doesn't work for you because it is for Creo 4 M040.
Best wishes
