Hello everybody,
I am trying to copy a surface and fill in a hole. when I select my surface and select copy and paste it brings me into the surface copy command. there is 3 tabs at the bottom of the ribbon bar, References, Options, and Properties. References and Properties tab open up when I select them but the Options tab does not. The text turns black when I select it but the drop down window does not show up.
Any ideas? I am using Creo 3.0 M030.
Thanks in advance.
I tried the mapkey and it did not work. So I removed M030 and installed M010 and it work! so I reinstalled M030 and now it works. I talked with Customer service and they think it was a graphic card issue.
Not sure I am convinced, I haven't updated my graphics card since last year.
Thank you guys for all the advice and things to try!
Is it possible that the drop down window became detached from the toolbar? If so, is there a way to locate it?
Adam,
on my PC, I can open all three tabs without problems.
Try to add the following option at the end of your config.pro file temporarily.
graphics win32_gdi
This option turns OPENGL graphics off. Then you can test Creo functionality. If the problem disappears, then you have to update drivers of your graphic card.
Martin Hanak
I tried the graphics option win32_gdi and the drop down window still does not appear.
Thanks for the thought!
Adam,
you can:
Martin Hanak
I made a cube and the copy command still will not give me the options pull down menu. I will try reinstalling the program.
I reloaded creo and it is still doing the same thing.
Adam,
if it is possible, install Creo on another computer.
Martin Hanak
My coworker has almost a match on everything and has no issues.
I reloaded M010 and it works the way it should. Not sure what to think?
Adam,
unfortunatelly I have not another idea what to check.
Martin Hanak
I have a call into PTC, so we will see what they say.
Thank you for shooting me some ideas.
Adam,
For a quick test create a block with a hole feature and run attached mapkey (Keyword is p). This mapkey is to select the surface > Copy > Paste > Options > Exclude ..... This may give us an idea whether is there something on your machine which is not blocking the expansion of tab.
Adam,
You may mark your reply as correct answer for the post.
