Orange Colored Dimension
akelly
Using Wildfire 4 with the Pre-Wildfire color scheme. So the background is blue blended, planes are red/yellow, dimensions are yellow, etc.
Have a part with wome model dimensions are orange instead of yellow. Just noticed it today. Happened on more than one model. The geometry measurement matches the dimension value.
What are orange colored dimensions and why?
Andrew Kelly, P.E.
Design Engineer
Honeywell Sensing and Control
2080 Arlingate Lane
Columbus, OH 43228
Office: 614-850-7818
Toll Free: 800-848-6564
Fax: 614-850-1111
andrew.kelly@honeywell.com<">mailto:andrew.kelly@honeywell.com>
7 REPLIES 7
wfalco
(To:akelly)
It happens every October.
GregHamel
2-Explorer
(To:akelly)
Locked/Modified Dimensions Enhancement
When dimensions have been modified or locked at a specific value in Sketcher, they now appear (by default) in orange.
The locked values are maintained when dragging sketched entities outside of Sketcher. However, locked dimensions can be directly selected for editing, if required.
Hi Andrew,
Yes these orange coloured dimensions are unusual looking but another reply
shows you that they are a new WF5 category called Locked. This gives them
extra properties compared to Strong which was the highest level before (see
below).
There are a couple of config settings to make dimensions automatically
Locked and we experimented with these at the start of WF5 but decided not
to go with them for our use. It can be that an individual user could add
this config option.
*sketcher_dimension_autolock* (automatically locks strong dimensions) and *
sketcher_lock_modified_dims* (yes/no)
Here is the HELP response to a query for "lock dimensions"
About Locked and Unlocked Dimensions
You can lock dimensions in Sketcher. Locking of dimensions allows you to
avoid modifications made to the sections outside the Sketcher mode by
accidentally dragging a vertex or an entity. The locked state of the
dimension is maintained when you quit or re-enter the Sketcher mode.
You can also set Sketcher to lock all user-defined dimensions automatically
by setting the value of the sketcher_dimension_autolock configuration
option to yes. Alternatively, click Sketch ▶ Options and select the Lock
User Defined Dimensions option on the Miscellaneous tabbed page of the
Sketcher Preferences dialog box.
After you set this option, all dimensions that you subsequently create or
modify are locked. Dimensions created before you set automatic locking
maintain their status.
Note
The locked state of a dimension is not retained if the dimension is
referenced in a relation, as the relation takes priority over the locked
status of the dimension.
To unlock a selected dimension, click Edit ▶ Toggle Lock or right-click and
choose Unlock on the shortcut menu.
Locked dimensions appear in orange. You can set the color for locked
dimensions by clicking View ▶ Display Settings ▶ System Colors and
selecting the required color on the Sketcher tabbed page.
*Brent Drysdale*
*Senior Design Engineer*
Tait Communications
Wait till November. Then they all fall down.
wfalco
(To:akelly)
sshannon
(To:akelly)
Naw. In November they become really vibrant as they turn “Hunters Orange” 😉
Just to clarify, these have been around since at least WF3. Not sure about before that…
