I have a drawing that uses ordinate dimensions, The refeence feature is modified/deleted and all of my dimensions change to purple.
I know how to update all of the dims except the main origin dimension (0,0)
The Edit Attachement does not work I also get the message: Functionality is not available on the selected item.
here is a screen shot
Any help would be appreciated.....Thanks
What your ordinate dimension what pointing at / attached to is "no longer there" do to your modification. It doesn't know what to do, so it changes the dimension to purple. You may have to redimension.
And welcome to the forum.
Exactly....I have to redemension, but is there a way inside of Creo to edit the attachment of the original diension so I do not have to redemension?
Not that i know
Right click the purple dimension or note and choose Edit atatchment.
The purple dimensions means that the references that you choose are unavailable or inexistant now.
When I right click on the origin dim (0,0) it does not give me the option to Edit Attachment.....that option does exist for all the other dims???
yes and for notes too
I don't know if it helps or if you have tried it, but if you right-click on the line rather than the dimension it might help, plus of course you have to be in the correct #%!!@ tab, i.e. annotate in this case.
I haven't been able to figure this one out either. Looks like there is no way to edit the base dimension attachment.
That's just too bad.
