Ordinate dimensions of holes on rolled sheetmetal part
JustinMoses
What is the easiest way to ordinate dimension a rolled part. I have holes that were created in the bent state. The flat instance deforms the holes so there is no axis or center location for the holes. Auto-ordinate dimension just gives the tangent locations of the deformed hole. There should be an easy way to do this right?
1 REPLY 1
What you can do is select midpoint when placing the ordinate dimension. See in attached picture.
