I have created a repair procedure consisting of about 12 sequence steps in Creo Illustrate 3.0. I am able to step through the sequence in Creo Illustrate.
BUT...
How do I export or output this procedure so it can be seen and followed by others?
Any help appreciated!
Tom Burton
Tom,
You can publish as a PVZ file and play the sequence in CreoView. Otherwise if you do the steps as a animation instead of a sequence you can export as an avi file.
I want to export as movie but don't want to do animation again. I already have sequence steps. Could you help to export as movie from sequence steps
You can play the sequence an record using a screen capture software like Camtasia.
