Dear PTC user's
Did RSD was is used in any piping firm?
What's the difference between RSD vs AVEVA DIAGRAMS vs AVEVA P&ID?
In RSD we can create catalogue?
Layers?
symbols?
Auto numbering for Equipment,Vallves,line fittings,pumps?
BOQ? Without duplicate?
Flag in and out connection?
If all possible, my life was saved in my enviorment. In new way.
Thanks&Regards
Viswanathan.K
yes, its companies its using
yes, there can be creted some kind of catalogue ( named and used else)
yes there is layers
yes there is symbols
there is valve numbers but other fittings recognised else
there is fluid direction if you ask about this
also creo have better visualisation, more modern workflow, other programs can be used as helping hand (ms excel for example)... so try and you see
yes there is layers
