PARAMETERS AND RELATIONS
cspinelli
Hi everybody,
i have a question about relations and parameters: i'm trying to make an udf to cut an involute gear but i cannot add a variable parameter as i've make them on part. if i make variable parameters on a feature i have to replicate on all the features, correct?
do you have any suggestions?
thanks!
A first create Annotation Elements.
Add all parameters and add relation, if needed.
Create all features, if need, I add realation for feature.
To UDF I add all elements with AE.
AE includes all parameters for create UDF.
This parameters I add to variable parameters UDF.
Image for UDF
6 REPLIES 6
I create for UDF Annotation Elements and add to him parameters and relations.
thanks, but you add annotation AFTER inserting UDF correct?
for example, in the image you added, if i want to insert UDF and change diameter or number of teeth when i'm inserting UDF is it possible'
Image for UDF
THANK YOU VERY MUCH!!
you have solved many of our problems!
i have another question: how do you use a parameter when you have to do a pattern?
in your and mine example number of teeth.
thanks
You can use parameters AE's or add as variable for UDF.
I use this parameters in famaly table for UDF.
