In Acrobat (or Acrobat viewer) when viewing these drawings try the following key sequence:
ctrl+5
This should set the line weight for visible lines so they are properly presented for viewing.
If you search a bit here you might find a past discussion about PDF line weights and the like. Perhaps the following result will prove useful:
Past PDF line output discussion
