Hi Lar,
I had the same problem when I configured my PDF export.
It seems to be due toAcrobat distiller not recognising the defaultProE font 'font3d',
so it replaces it with a font that has slightly different spacing / formatting.
I decided to use the Arial True Typefont as it looks clean and crisp.
Here's what I did to resolve the problem:
I set the following options inmy config.pro fil
PRO_FONT_DIR C:\WINDOWS\Fonts
DEFAULT_FONT Arial
Then I edited the properties ofmy existing drawing formats, drawing templates required drawings,
setting the font to Arial.
I had toeditthe text style of drawing tables (eg. Title block) setting the font to Arial.
I also set the font to Arial in my drawing setup file (.dtl)
Once I madethe changes, the textinPDF's was exactlythe same as the text displayed in ProE.
Hope this helps
Colin
